water pressure tubing >
Old 12-09-2009 | 09:21 AM
Ken N's Avatar
Arrow water pressure tubing
what kind of tubing is used on a water pressure gauge and who handles the kit
Ken N is offline
Old 12-09-2009 | 09:43 AM
Most gauge kits use 1/8" poly tubing. You can buy the tubing and fittings from any hardware store. I don't like the tubing so I use 1/4" rubber hose. You can use either fuel hose, or a more specific hose like push-loc hose from Russel, Earl's. Aeroquip, etc. You can order it from Summit or Jegs, etc.
You can also order a full kit from Livorsi with the gauge and the tubing and fittings.
Eddie
Young Performance is offline
Old 12-09-2009 | 12:04 PM
Arrow
I use Pisco tubing, since we have them at work in various sizes. 1/8 is the sizeyou need.
http://www.pisco.com/category.aspx?catid=12
spectras only is offline
Old 12-09-2009 | 01:36 PM
Livorsi sells the tubing and fittings
BenPerfected is offline
Old 12-10-2009 | 01:47 AM
The plastic tubing likes to kink pretty easily. If you use it, leave a couple extra feet coiled up, especially if you use teh block drain to feed it. The tubing can clog and it is sometimes easier to cut off a few inches than to try and unclog it.
Griff is offline
Old 12-10-2009 | 12:20 PM
737jetmech's Avatar
Default 1/4 air hose ...
I found some 1/4 inch air hose at The Home Depot .It is gray in color . It came in a 50' roll for about 35 dollars.
737jetmech is offline
Old 12-11-2009 | 12:18 AM
Arrow
Yep, that's why I recommended Pisco , it's very flexible and takes very high pressures . I use Pisco for my drive shower with quick connect fittings .
