powdercoating drives >
Old 12-14-2009 | 08:47 PM
Default powdercoating drives
My drives are in need of repainting and i was thinking of having them powdercoated after I tear them apart to go through them. Is there any issues with the heat from this process warping anything?
AB69Z is offline
Old 12-14-2009 | 08:55 PM
I would paint them. Once powdercoating gets a chip, it turns to chit. It will get little bubbles under the PC and then start chipping and peeling all over.
Griff is offline
Old 12-15-2009 | 12:22 AM
2112's Avatar
Griff,
Do you know what paint Merc uses?
2112 is offline
Old 12-15-2009 | 01:31 AM
No, but I believe it is just an enamel. If I was going to repaint mine, I would probably go with Imron.
Griff is offline
Old 12-15-2009 | 04:41 AM
Mr Gadgets's Avatar
Charter Member #601
I know a guy that uses a good epoxy primer and Dupont Centari Enamel..
I have seen power coating flake off as has been mentioned. If you can keep the coated stuff out of the water, it seems to hold up better..
Dick
Mr Gadgets is offline
Old 12-15-2009 | 08:28 AM
thinking of painting mine this winter as well, Imron Paint... does this stuff need a clear coat ? Sometimes I leave the boat in the water for two weeks, any problems with that and the Imron, besides getting a little dirty/ skummy?
poiuy10 is offline
Old 12-15-2009 | 09:06 AM
No paints are actually recommended for below water line use, but Imron holds up about the best. Imron is actually a line of paint. There is a version that use a basecoat/clear and a version that does not require a clear.
Griff is offline
