BBC oil pump ? >
BBC oil pump ?
BBC oil pump ?
Old 12-15-2009 | 08:03 PM
Default BBC oil pump ?
what oil pump should i use on my rebuilt 509 with 2.3 whipple side mount? thx
conquest30' is offline
Old 12-15-2009 | 09:03 PM
H2Xmark's Avatar
http://moroso.com/catalog/categorydi...?catcode=14444
H2Xmark is offline
Vinny P's Avatar
I hate the winter!!
I like Melling 10778 or 10778c pumps. Although some guys here dont like the "C" pumps, I have used them on 3 engines recently with great results. There have been claims of the "C" pumps causing pressure fluctuations at idle speeds, but the 3 engines I did, didnt experience that problem.
Vinny P is offline
Old 12-15-2009 | 10:24 PM
which one moroso or melling? then which model? lol thanks
Old 12-15-2009 | 11:35 PM
Wink
Vinney P and I both concurr!
Raylar uses the Melling 10778c on our BBC engines exclusivly and we have nothing but excellent results.
These pumps are the best because they have bearing support at the top and the bottom of the oil pump gears, which stops gear seperation at high loads which is why you see uneven wear and gouging on the old style pumps in the cover.
We do throw away the extra spring in the box, don't use it its not right or even close and we do weld the pickup tubes in place carefully (not to much heat) with the cover off and then re-install the cover and torque cover bolts and check pump feel under rotation again.
These pumps are reasonably priced and they represent the best value in BBC oil pumps today!
Best Regards,
Ray @ Raylar
Raylar is offline
Old 12-15-2009 | 11:40 PM
cool i will go with that pump then, i have a aftermarket pan with a bolt on pick up so i dont think there is any reason to weld it on. right?
Old 12-15-2009 | 11:44 PM
i am going to plug the bypass in the filter mount also with a 20mm freeze plug, or should i put a 30pound spring instead?
Old 12-16-2009 | 12:34 AM
Plug it or tap the hole and install a 1/2" pipe plug. I tap and install the plug.
Also, I use a M77HV pump. It is the only pump I have ever used for over 20 years and have not had any troubles with them.
Eddie
Young Performance is offline
Old 12-16-2009 | 08:59 AM
Eddie
Eddie, 1:35 AM??? Do you ever sleep? It never ceases to amaze me that you are so willing to spend your limited time sharing your expertise on this site.......
TCBoss302 is offline
Old 12-16-2009 | 09:43 AM
I had a after market bolt on style pickup, it was not welded on and cost me a motor. The bolt worked out, pickup fell off, and BOOM, two rods through the side of a $12k motor. now I weld it on no matter what.
tx911 is offline
