Any benefit of extension box on Y2K?
I'm just puzzled that with 775 hp I'm only going 84.5. I did do 90 once, but since that one time I can't break 84.5. Maybe the motor is missing somwhere. I wished for a 28 skater with O/B for christmass but didn't get it!
I'm just wondering how it compares to the imco unit with 3" lift...
ITS isnt adjustable The center of the lower unit is 1 1/2 " below the bottom on my setup. I tried a 1" spacer a while back but liked it better without.
Kendall
Temp and humidity and water cond. play a huge role in how my boat performs. I've had many different results on different days...
Kendall
Kendall
Kendall
I believe the JCap did the most testing of anyone on the Y2K.
The extension box did not help and neither did a shorter drive.
I believe that on the first generation Y2K hull, the factory set prop shaft height of 3-1/2" below with no extension is about as good as it gets. JCap did run with a 1 or 1-1/2" spacer for racing but went back to the stock length for reliability reasons.
The Zuperboat is the only 30' Super that we've talked about here that ran well with an extension box. The boat is vary light and has the tempest deck. I'm sure Mike is happy to tells his stories again.
Patrick
Patrick
