Water hose connection help (serpentine) 454 / 502 mag >
Old 01-08-2010 | 01:53 PM
Default Water hose connection help (serpentine) 454 / 502 mag
Can some one look at their engine or service manual and tell me if the fresh water hose from the drive connects to the top nipple on the sea pump or the bottom.
Thanks in advance Mitch
22 DAYTONA is offline
Old 01-08-2010 | 01:55 PM
it's on the top on my BAJA. To oil cooler and engine on the bottom.
Advantage 575 is offline
Old 01-08-2010 | 02:55 PM
The hose from the drive goes to the bottom of the pump. The top pushes water to the engine.
fbc25el is offline
Old 01-11-2010 | 10:16 AM
That is the way I have mine hooked up, but now it sounds like the one on the Baja is coming from the drive to the top of the pump. Anyone have the install manual on the 2001 502mag or 454mag?
This was a picture from the dyno. When I looked at it magnified, it looked like the water in was hooked to the bottom. The hosed were not connected when I got it.
Old 01-11-2010 | 07:27 PM
PAST DUE's Avatar
look at the back of the pump it will tell you which one is outlet for the corresponding direction of rotation.
PAST DUE is offline
Old 01-11-2010 | 08:01 PM
Also when you go to start the engine just have your hand on the impeller housing, If it starts getting warm you have the hoses hooked up wrong, If it stays cool then you are ok, You will know within 15 seconds if you got it right or not by feeling it.
Boat Tech is offline
Old 01-11-2010 | 09:02 PM
on mine the lower hose comes from the drive
mike tkach is offline
Old 01-12-2010 | 06:14 AM
Heavy walled hose goes on the suction side of the pump.
flexible hose output side.
Ken
minxguy is offline
Old 01-12-2010 | 09:48 AM
Thanks fellas.
