TRS Trim Sensors
Just wondering where is a good place to buy TRS trim sensors. The best price I have found so far is $85 for the sensor and limit switch (for both sides of the drive) shipped to my door. That seems fair to me, but I wanted to make sure that there isn't a site on here that everyone uses or anywhere to get them cheaper.
Don't think your going to find it much cheaper. Here's one from a place I have delt with and have pretty good service. Don't know if it would be any cheaper though once you add on shipping.
http://www.perfprotech.com/store/pro...A-2,24554.aspx
Would these fix my issue where sometimes my drives get out of sync w/ each other when raising or lowering? A couple of times i have had to keep working the switch to where the indicators finally showed they were even.
(they will, however, cause your normal individual up/down trim switch to not work, forcing the operator to use the trailor trim switch to trim the drives)Your issue sounds more like a worn out ram on the slower operating drive, or perhaps an issue with the way the plumbing is rigged that is causing one drive to operate slower than the other.
I know it is annoying (mine aren't perfectly matched either), but I just remember which drive is slower and I don't hold the other switch down all the way when I'm adjusting trim. To me that seems to make a lot more sense than getting frustrated chasing the problem, rebuilding rams, building new lines, etc.
No. All they do is tell where the drive is. Those stock type sending units aren't very accurate either. Also you need to be sure the sending units are in sync with each other. To accurately tell what's going on you need trim indicators.They use a cable from the drive to a guage on the helm to tell you exactly where the drives are. If they are getting out of sync while raising or lowering then the trim system is working better on one of the drives than the other.
I have a few of these trim sensors laying around that are new. I have never had any luck with the accuracy of those things either. I use to locktite the hinge bolts also. At times they will move one way or the other throwing off the sensors big time. I always end up running by the seat of my pants. Not always the right way though. I am going to convert to the mechanical ones.
If you want to off a pair of these for less than I'm going to pay for them, let me know. The main reason I need a set is because my limit switches are toast, and i now have to use the trailer setting to trim the drives.
