Ecu
Would the ecu cause the motor to not start if it gets hot? I'm having issues after starting and running for a while the motor doesn't start until it gets cooler when the sun goes down...which isn't ideal situation. Other thought was might be the coils.
Travis
You may need the Check Valve Kit.
http://www.marineengine.com/boat-for...r-lock-or-what
http://www.boatfix.com/merc/bullet/99/99_07.PDF
