496 to 496 ho conversion
I have a 375 hp 496, the block cracked (and the 525 I really want seems unreasonable right now)
If I purchased the 425 horse version (in a long block) can I have my computer re-calibrated for that engine?
Would I need anything else to make this a true HO?
to make the conversion you need a cam ,the hole in the throttle plate needs drilled ecu need reprogrammed by whipple ,he can give slight up grade at that time 10% on top
what do you drill the idle air hole on the throttle plate ?I heard drill it out to a 1/4 ,is that correct?
If the camshaft in the new long block is the 425HO version , you're good to go on the engine. You can send us the ECM and we reprogram them to HO spec for $675 each. Let us know if we can help.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
I have an HO cam and ECU I'll sell for $750. Just get the reman long block and swap cams.
Bob
Bob
007joe:
The Raylar HO replacement camshaft and our in house ECM reprogram will raise the horsepower to about 460HP with everything else stock.
Best Regards,
Ray @ Raylar
Best Regards,
Ray @ Raylar
