Adjustable ball mount
Old 01-13-2010 | 08:04 PM
Default Adjustable ball mount
Looking for a source for an adjustable height ball mount, 14,000-16,000 lbs
ciaoderhead is offline
Old 01-13-2010 | 08:22 PM
all the ones I have seen only go up to 10K. I was looking for a 6" drop or adjustable rated for 15K and had to get a 6" drop only. I do have a nice adjustable billet hitch but its only 10k.
tcuda499 is offline
Old 01-13-2010 | 09:32 PM
In order to get 15,000# you need a class 5 hitch which has a 2&1/2" opening instead of the standard 2". I have a weight distribution insert which has a series of holes for different height adjustments. If you need one I can gladly get it for you
snogiyogi is offline
Old 01-14-2010 | 02:16 PM
I found a bolt together like you described. Thanks!
Would really like a quick (pin) adjustable one. Have several trailers I tow and all are slightly different heights. May end up with the bolt together and a sleeve for the lighter trailers.
Old 01-14-2010 | 02:35 PM
Dock Holiday's Avatar
Charter Member #34
I have never seen an adjustable in those capacities.
The more components the more there is to fail and the more weak links.
Dock Holiday is offline
Old 01-14-2010 | 08:33 PM
yep, looking like a dead end....
Old 01-15-2010 | 03:02 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
This would be my only suggestion Lin:
http://www.etrailer.com/dept-pg-Acce...on_Shanks.aspx
You would have to buy a WD plate to attach to the shank as well, and they bolt together, not pins. However, you do have adjustment.
Poke around the rest of that sight. They have a lot of stuff including a 3" drawbar for a 3" hitch which I have never heard of until now.
Sydwayz is offline
Old 03-12-2010 | 02:04 PM
I see the pretty aluminum adjustable ones all the time towing 15K+ lbs worth of boat. Scares the hell out of me. I looked for an adjustable 15K as well but didnt have any luck.
Kieffer4 is offline
Old 03-16-2010 | 12:53 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Just came across this tonight:
http://www.cabelas.com/cabelas/en/te....form23&Go.x=0
Sydwayz is offline
Old 04-29-2010 | 09:04 PM
Originally Posted by Sydwayz
I just bought that hitch cabelas was sold out but uhaul has them for 139 seems to be well made and nice having the 14000 rating
andyt25 is offline
