Head Gaskets >
Head Gaskets
Head Gaskets
Old 01-16-2010 | 10:34 PM
Default Head Gaskets
What are the thoughts on the best head gaskets brand and material.
I am building ~500 horsepower 454's. They are 0.030 over. What are the thoughts on copper? What size gasket diameter should I uses for a 4.280 bore?
OhioRiverCigarett is offline
Old 01-16-2010 | 11:45 PM
i use the fel pro marine gasgets on every bbc marine engine from stock to supercharged.gasget bore needs to be at least .010 larger than cylinder bore.i only use copper on all out dragrace engines with reciever groove &o rings.
mike tkach is offline
Old 01-17-2010 | 05:19 AM
Vinny P's Avatar
I hate the winter!!
Personally, I only use Cometic gaskets.
Vinny P is offline
Old 01-17-2010 | 07:59 AM
I use both Felpro and Cometic but for your application Felpro marine gaskets are all you need.
brian41 is offline
Old 01-17-2010 | 08:00 AM
I would not use copper, my race engines use them and they seep water, not needed in that felpro's work fine...
ezstriper is offline
Old 01-17-2010 | 09:03 AM
Smitty's Avatar
Fel-Pro MLS gaskts
Smitty is offline
Old 01-17-2010 | 09:41 AM
PatriYacht's Avatar
Felpro blue teflon composite gaskets are all you need for this application. Anything more is a waste of money. Copper is a headache that only super high boost requires.
PatriYacht is offline
Old 01-17-2010 | 12:21 PM
Patiryacht hit the nail on the head on every point. I love the Cometics, but they are just not needed in your application. The correct Fel Pro gasket for your application will have a 4.320 bore size, I believe.
Eddie
Young Performance is offline
Old 01-17-2010 | 12:23 PM
+1
formula 382 sr-1 is offline
Old 01-17-2010 | 07:17 PM
Rookie's Avatar
Fel Pro 17042 for your application.
http://www.amazon.com/Fel-Pro-17042-.../dp/B000CEMIDQ
Rookie is offline
