Alpha upper
Old 04-15-2002 | 04:46 PM
Mother
Default Alpha upper
I actually have 2 questions:
1) how do you split the alpha apart? I've gotten the 3 nuts on the 'gimbal' side of the drive, and the two on the bottom of the ventilation plate, what now?
2) What constitutes a usuable core on the upper case? When my gear went the case got gauged around the the outside of the driven gear, is it now trash? I can't see how that section of the case would affect anything except peraps oil splashing, and then you could just putty it up and hone it??
Thanks in advance,
--Adam
P.S. As I had feared, the #%^@! that sold me the boat put a 1.5 (20/22) drive on the boat... Behind a damn 454.. WTF! That helps explain the brief drive life...
Old 04-15-2002 | 04:50 PM
ForrestC's Avatar
Now remove the zinc trim tab with an allen wrench and you will find another allen-head bolt under the tab. It's got to come out too.
ForrestC is offline
Old 04-15-2002 | 05:02 PM
Mother
DOH!
Thanks Forrest
--Adam
hoozeyurdaddy
Drives and Lower Units
0
07-18-2008 08:18 AM
chriscorso
5
05-19-2007 11:16 PM
cbgenrl
3
04-18-2006 09:12 PM
nsphillips
10
08-29-2005 07:00 PM
