Old 01-21-2010 | 03:25 PM
Registered User
Default 427
whats a 1968 427 l78/l88 worth cab to pan
itbs is offline
Old 01-21-2010 | 04:09 PM
Steve_H
Could be worth alot to a car guy.
Old 01-21-2010 | 04:20 PM
Not much in a boat but the corvette guy's will pay lot's for a GOOD L88 engine.
Jeff P31 is offline
Old 01-21-2010 | 06:14 PM
It would depend on a lot of things, mostly how original it was. If it's a L88 it would be worth more beings they used the aluminum heads. L78 had cast iron heads. I would think a used L88 in ALL ORIGINAL CONDITION,never rebuilt would be worth at least 12K.
picklenjim is offline
Old 01-21-2010 | 08:03 PM
Registered User
it has winters alu heads gm alu intake holley 3 barrel carb has never been apart numbers of front of block t0403it
itbs is offline
Old 01-22-2010 | 02:41 AM
go to corvetteforum.com
rdoactive is offline
Old 01-22-2010 | 07:05 PM
Default Fixx
it depends on the buyer,sounds like you got a 430 hp engine but in reality that motor produced 530 hp..If it is a 1967 build for a corvette which only 20 were made with that alunimum head motor i would say you could get a pretty penny for it..i sold a l88 to a corvette guru about 6 yrs ago for 5k - the intake and carbs...with it having the alunimum heads i wouldnt let it go for under 7k..
FIXX is offline
