sunpad question
The sunpad on my boat fills up with air when going fast so the skin starts flopping up and down,anybody else have that problem?
Is there anyway of stopping it from doing that?I installed vents on the sides but didnt really help,other then glueing the skin to the foam is there anything that could be done?
sun pad is stapled underneith.
Mine would lift at the rear at speed and kinda' looked like a small spoiler. Had the local canvas/upholstery guy fix it, what we did was to take the entire cover off, then added a very high density 1/4" layer of foam laminated to the top of the factory foam pad, then reinstalled the skin. He also added some xtra vent holes to the pad base to let air out better. Vynil is a fabric and as such can stretch with time and use, mine was a little loose and that was the basic cause of the spoiler effect. Thing to remember is when you reinstall it get it snug, but not so much so that it puts too much strain on the stitching. That is where the beefed up padding comes into play, allows the skin to be snug but prevents a lot of the flex when you are on it. Guy did a super job, looks and feels much better, and no more spoiler even at 90+. Hope this helps.
Good work.
was thinking of spraying adhesive on it but not sure that I want to make it one with the foam
Boatnt,
I have a Checkmate with the same problem. The vinyl would ripple and build up towards the back. I had a tear (dont ask) in the skirting around the edge. When I went to have it fixed
I had the upolster add a 1/2" or 1" of foam just to make the pad softer.. Well it cured the ripple effect, and the pad feels much better than before.
Dick
Dick
