Trolling motor
ok this may be a dumb idea but I saw some cheap trolling motors today and got me thinkin about having it as a back up.
When my drive blew up I felt completely helpless and moving towards a jagged rocky shore.. It`s small enough to fit in the engine bay... question is would move the boat? even if for short distance or just to buy some time...
http://www.cabelas.com/cabelas/en/te...questid=135789
I remember seeing a pic once of a turbine cat that installed a small trolling type motor on top of the trim tabs for maneuvering without firing up the turbines.
I am sure it would work in an emergency but I wouldn't rely on it to get you back to the trailer.
If you are going to go that route spend a little more money on a 4hp gas and you might make it back to the ramp.You would need a big trolling motor and if it was windy i don't think you would move.
Where would you mount it?
Best one to get and it will move you a little, its the lightest one I know of
http://marine.honda.com/Products/ModelDetail/BF2
plus its a four stroke, so if you had to you could get fuel from you tank in your boat, you would need to rig something??
Some of the reviews make me believe it could work ok in a jam
For a $100 I think I may try it. if its no good I`ll put it on a pool raft
"pushes my 14' v bottom well even on a windy day with 3 people and motor and gear.
does better than my old 35#moter guide that was 15 yrs old"
"I bought this motor for a 12' john boat, it works great and moves the boat just fine. I troll on mountain lakes for trout and this motor goes all day on just one batterie."
"I put this trolling motor on an all-welded aluminum jon boat. The boat is 14 1/2 ft with a beam of 56". It has a 25 Yamaha and with me, all my gear and one other person it has no trouble pushing this boat along at a good speed. It works well in weeds and is easy to operate. I would recommend this for any one looking for a good, reliable motor."
"ok first of all this motor was perfect for what I wanted to use it for, I constructed a motor mount on the rear of my pontoon boat, 9ft, and I located two 9in +7in deep cycle batteries, first time on the lake with the 5 speed motor I was impressed with the thrust, and the mobility of the motor, and the telescoping control is a plus...quite and smooth, I would recommend this product to anyone..."
