wtb - TRS wingplates and tie-bar >
Old 01-30-2010 | 02:29 PM
Default wtb - TRS wingplates and tie-bar
Looking for TRS hydraulic steering attachments for twin TRS drive application. I don't care if they are wingplate or some bolt on plates, I have the rams and other transom components.
Boat1 is offline
Old 01-31-2010 | 09:59 AM
I have a pair of wingplates
smiklos@sunprint is offline
Old 01-31-2010 | 10:39 AM
Please send pictures and price to [email protected]. Thank you.
Boat1 is offline
Old 02-01-2010 | 05:31 AM
O.C.Barry's Avatar
Default Tie bar
I have a nice tie bar. The rod ends were just replaced. Barry
Thanks, Barry
Driver - High's Fuel Your Journey Cigarette Racing Team #598
O.C.Barry is offline
Old 02-01-2010 | 06:24 AM
c_deezy's Avatar
Honestly for what the 'wingplates' are from most places, you could easily go to a local metal fabrication and they could probably make them for you in less than an hour if you took them the dimensions. The ones I got from CP were little more than a plate of stainless with the ram mount welded onto it and they were a couple hundred bucks iirc. Of course I wasn't the one paying and time was of the essence...
c_deezy is offline
Old 02-01-2010 | 09:27 AM
I've only seen the wrap around wingplate that attaches to the drive studs. I'll check out the plate your describing. This is not a real go fast application, the original steering bars are totally worn out and I'm looking to add-on hydraulic rams to replace the existing bars inside the boat. Thanks for the info.
Boat1 is offline
Old 02-01-2010 | 06:56 PM
Yep,
I just drilled the stainless for mine today. 1/4" base plate and 1/8" thick SS316 ram mounts, two per side, sandwiching the heim joint. I haven't tried bolting the base plate up yet so not sure if I measured it up right. I THINK the TRS bolt pattern is 4-15/16 x 4-1/16.
Gotta find a good TIG welder around here.
Randy
bustedbrick is offline
Old 02-01-2010 | 09:03 PM
Rookie's Avatar
May I ask where you bought the tie bar ends at?
Rookie is offline
Old 02-01-2010 | 09:57 PM
Miller Bearing is where i got mine....but heim sux.... Go clevis so u don't bend a heim....or worse....
commandersander is offline
Old 02-01-2010 | 09:59 PM
And by the way.....
Wing plates on a TRS are waaaay more than a simple plate...
I have them on mine. It goes over the top (4 bolts and spacers) and down the face (another 4) and the pin for the clevis is a specialty item....not readily available from the hdwr. store....
