Looking for 540 merlin block >
Old 02-03-2010 | 02:58 PM
Default Looking for 540 merlin block
I am looking for a 540 merlin III block, 9.8 deck, let me know what you have, thanks
halfbuzzed is offline
Old 02-04-2010 | 10:01 AM
or maybe two dart blocks?
Old 02-04-2010 | 02:26 PM
I have a 509 built on a Merlin block just up the road from you in Mentor. 4.5" bore, Merlin iron heads, Merlin marine intake, etc. etc. with about 10 hours on full rebuild (I have receipts). Pulled her out of the boat after end of season, complete pan to intake. Let me know if you have any interest.
DucBoy is offline
Old 02-04-2010 | 02:29 PM
I have never seen them cheaper than this.
http://www.offshoreonly.com/classifi...o10839-en.html
jeff1000man is offline
Old 02-04-2010 | 03:55 PM
Yeah, I called that place, but they only have 4.25" bore, so the machine time would add up
Old 02-04-2010 | 04:31 PM
KAAMA's Avatar
Not 100% sure, but I believe a Merlin III block only comes with a 10.2" tall deck.
Anyway, I have a pair of Merlin II 9.8" short deck blocks that were built to 565cid, AFR 315cc CNC ported heads massaged by JimV, billet distributors, Holley 950cfm carbs, Jessel shaft mount rocker arms, hydrualic roller cams/lifters by Bob Madara/RMBuilder, Lunati fully counterweighted cranks, Eagled H-beam rods w/L19 rod bolts, JE flat top pistons, 9.5 comp ratio, GIL 10-quart oil pans, Hex Adjust timing chains, polished Dart single plane intake manifolds w/massaged plenums, Fluid Damper balancers, FRESH WATER USE, 230 hours, machined, blue printed/balanced/assembled and dyno tested by Dave Wesseldyk of WESCO in Jension, Michigan. $11,900 per engine.
KAAMA is offline
Old 02-04-2010 | 06:34 PM
Default 2 Bowtie 502 Blocks + Merlin Heads + HP500 Induction
FOR SALE:
(2) GM Bowtie 502 Blocks w/main caps, both standard bore
(4) Merlin Heads, bare, steel, rectangular port
(32) Crane Gold Rockers 1.7
(32) Manley Pushrods
(2) Mercury Racing HP500 Dart intakes and Holley carbs (NEW take-offs, never ran)
Moved up to tall decks and blowers
Everything goes as a package: $5000
TX3x2gun is offline
Old 02-05-2010 | 09:32 AM
ttt
Old 03-02-2010 | 12:13 PM
i am looking for a pair of fresh gen 6 540's. anybody? thanks tom
500hps is offline
Old 03-02-2010 | 01:01 PM
302sport is registered here on OSO. He has 2 540S with low hrs for sale....
kreed is offline
