intake 454
Old 02-09-2010 | 06:09 PM
Default intake 454
what is a good intake for a 454 with a tad bit bigger cam than stock, and imco exhaust, that would be better than stock intake on it now. it is a older late 80s motor in a 25 checkmate.
rssteiny is offline
Old 02-09-2010 | 06:11 PM
If intersted I have this.
http://www.offshoreonly.com/forums/s...rb-set-up.html
crapr6 is offline
Old 02-09-2010 | 06:39 PM
I would just go with the RPM. It's a good intake for stock or even with upgrades.
getrdunn is offline
Old 02-09-2010 | 06:47 PM
GRD, have you used the RPM airgap intake from Edelbrock? I've heard good things, but don't have any experience myself.
wjb21ndtown is offline
Old 02-09-2010 | 06:57 PM
Elelbrock victor jr single plane with Holley 750 double pump.
plumb crazy is offline
Old 02-09-2010 | 07:41 PM
I have not used it personally however keep up with the shop talk at the speed shops. That intake seems to be the number 1 choice for most any engine build from 454-496. My latest 496 builds I went with Darts however was a tuff decision to make. 496 in my opinion is borderline. I have never been in big fan of single plan on anything less. You sacrifice low and mid.
getrdunn is offline
Old 02-09-2010 | 07:47 PM
RPM airgap intake from Edelbrock hot rod guys did a test on big blocks and the air gap came out on top of the intake . . for wt you are bluiding i think this is for you
bajabob is offline
Old 02-09-2010 | 07:57 PM
Default Fixx
Rpm airgap! or if you want to spend a little less then the professional products crosswind is the same intake but has a little longer intake runner but lass money...
http://www.professional-products.com...uctBBchevy.php
FIXX is offline
Old 02-09-2010 | 08:20 PM
Now that you got that out of the way you might as well throw that 278 comp cam in there to really appreciate that intake. LOL...
getrdunn is offline
Old 02-10-2010 | 03:31 AM
I run the RPM Air-Gap, but have tried the Victor Jnr, the Torker, Torker 2.0 and a Dart intake. For your set up (and most others too) the RPM Air-Gap is unmatched!
Make sure you get it gasket matched to the manifold gaskets on the intake side and try and get the heads matched too.
I haven't seen the 'Crosswind' product but the Edelbrock quality is second to none.
Good Luck!
Ghostrider is offline
