Back of boat pics with twins
Just wondering if someone could post a pic or two of the back of there boat with there drives in a downward position. Just looking for some comparisons. V-bottom with twins, 28 to 36ft. Bravo or TRS drives.
It's to late to explain right now however this will help me out a lot.
Thanks very much,
John
Thanks very much,
John
OK, I'm curious? You forget how it all goes back together? I have a few pics of the back of the cat when the Bravos where still on it. Not a "V" but shows where it all goes. Just farther apart with a big hole in the middle. Let me know what you need.
The First Picture, probably won't help you, but its my 35' mistress that I owned. This is after I took off the TRS and put on Konrads which are 1.7" shorter then the TRS.
The Second picture is my 38' Top Gun with SSM IIIA's, they have a super high x dimension, they run like surface drives almost. Setup at CHIEF ENGINES.
The last picture is the mistress with the original TRS setup and conservative Cigarette deep x dimension.
Hope this helps a little
