who makes the best air cleaner????? >
Old 02-20-2010 | 09:17 PM
Default who makes the best air cleaner?????
ok i have k/n not shure its the best can i get a better onewith out loseing hp?????
bajabob is offline
Old 02-21-2010 | 08:59 AM
hoozeyurdaddy's Avatar
there's not much dirt on the water, all you need is good spark arestors. there are a lot of different styles out there and at a wide price range, what engine are you running?
hoozeyurdaddy is offline
Old 02-21-2010 | 09:09 AM
i am runnig 540dart just redone 650ponys. . i ask this?? because a few guys say some spark arestor are better than other ?they say some of them take hp away from the motor ? so thats y i am asking??????
bajabob is offline
Old 02-21-2010 | 09:28 AM
if you run a 10" x 3" it would be plenty for your engine, look in cp performace or eddie marine, I have seen some on the classifieds here also. you will get more restriction from a K&N than you will a spark arrestor of the same size.
Old 02-21-2010 | 09:37 AM
Summit Racing has spark arrestors may cheaper than CP or Eddie marine.
plumb crazy is offline
Old 02-21-2010 | 10:15 AM
I have seen lost HP with the K&N on the dyno. The gaffrig 10 X 5 ( good up to 1250 CFM) will flow good for that application with no power lose, might get away with the 10 X 3 .
brian41 is offline
Old 02-22-2010 | 01:17 AM
Strip Poker 388's Avatar
Rob
The base plate makes the most diff, then just run a wire mesh 1 layer.
This air cleaner made 9 hp compaired to no air cleaner on my 355ci 500hp Chevelle http://www.daymotorsports.com/produc...ILTER-ASSEMBLY
Strip Poker 388 is offline
Old 02-22-2010 | 07:12 AM
DiamondPerformance's Avatar
Offshoreonly Advertiser
To be legal, the flame arresters have to have a Coast Guard stamp.
www.diamondperformanceparts.com
[email protected]
http://www.facebook.com/pages/Diamon...07878772615803
302-521-0123
The Best Parts & Service At The Best Price
DiamondPerformance is offline
Old 02-22-2010 | 07:22 AM
Do they make any wire mesh only for the Merc 600sci's? I have K&N's right now.
chattviper is offline
Old 02-22-2010 | 03:32 PM
Default K&N Air Filter
I have never seen a K&N air filter on a carberated race engine. I have been to several offshore events as well as Poker runs.
The biggest application of air cleaners is the oval 3X10 using stainless steel wire mesh to keep out debris. Why would anyone with a high HP motor want to choke the air intake system?
Spend tons of money and give everyone a laugh with a car air filter!!!!
sideline is offline
