Water flow
Hey guys,
I need some help plumbing all my water lines as this is my first boat with a stern drive. I have a 454 with a TRS drive. The raw water pick up is on the bottom of the hull. I need some sort of diagram. I plan on running a raw water pump and circulating pump if that matters. Thanks!
Raw water to bottom of circulating pump, circulating pump to T-stat housing, T-stat housing to exh. manifolds... If I remember correctly. There are a TON of pics though... I would search TRS on E-bay classifieds or on here and see what comes up. I'm sure you could have 5-6 pics in a matter of minutes.
Confirm with Eddie at Young but in a previous post he suggested the 2X8OAL which is our 2X5 bundle length. End caps measure 1.5 inches on each end.
http://www.mrcool.us/catalogsearch/result/?q=205+ee-05
