Maintainence Tidbit >
Maintainence Tidbit
Maintainence Tidbit
Old 04-18-2002 | 09:57 PM
Tinkerer's Avatar
Cool Maintainence Tidbit
If you are having problems with your neumatic (air) cylinders on your silent choice. To lubricate them DONT USE ANY OIL this will make them worse. Use dish soap - PER MERC. TECH.
Tinkerer is offline
Old 04-19-2002 | 05:53 AM
Default air cylinder lube
Try using performance chain lube from a good bicycle shop. It is wax like in substance to stay on the chain and has characteristics of soap but better. It is designed not to pick up debris. It comes in small plastic squeeze bottles and is easy to store in your tool box.
Good luck.
deboatmon is offline
Old 04-19-2002 | 05:09 PM
Budman's Avatar
From: Kentucky - where the women are so fast we have to put a governor on 'em!!
Question What part are we lubricating
Can you guys elaborate a little more? Are you talking about lubricating the linkage to the divertors, the divertor pivots themselves, or the pistons within the actuators. The latter is what i am suspecting, but I want to make sure.
Budman is offline
Old 04-19-2002 | 06:45 PM
Tinkerer's Avatar
Cool
The pistons within the neumatic cylinders and you DON'T want to use any oil product as it will only make it worse. Just put some dish soap in the little hole on the side of the cylinder and work it back and forth. Was having a problem with them and tried all kinds of lube -nothing worked - just made it worse. Called and they said to use dish soap...
Tinkerer is offline
mv35
Swap Shop
0
07-23-2008 02:53 PM
Chris Sunkin
5
01-24-2008 12:49 PM
