S/s Corsa Slant Tail Pipes >
Old 04-19-2002 | 10:39 AM
HENRY SHARP
Question S/s Corsa Slant Tail Pipes
I HAVE A BAJA 25 OUTLAW w/ 496HO I WAS TOLD THAT MERCRUISER WOULD NOT WARRANTY IF WATER GOT IN TO MANIFOLD , HAS ANYONE HAD A PROBLEM WITH THIS I AM THINKING ABOUT INSTALLING THEM ?
Old 04-19-2002 | 12:00 PM
BajaBoss252's Avatar
I just pulled the Corsa Q&Q II mufflers off of my Boss 252. I'm putting Hardin Marine angle cut tips with internal flappers on. $138 for the new tips. I think it will be fine. The flappers should stop the water reversion problem, that's what they are there for. You probably won't get reversion anyway unless you have a real lumpy cam...
BajaBoss252 is offline
Old 04-19-2002 | 08:36 PM
I've had Corsa tips on my (small block) boat for 5 or 6 years with no problem, but mine have the internal flappers and baffles, which may not be on yours. Call or e-mail Corsa; they will most likely tell you if there is a potential problem with your set-up.
arks is offline
Old 04-21-2002 | 08:58 AM
steve chalupka's Avatar
H -
I just had Corsa ss angle cut tips installed on my 272 Boss Baja and had the same concerns. I spoke to Dennis Hannes at Corsa ([email protected]) and he assured me that because there is a "carek" valve (or rubber internal flapper) built into the tips it prevents water from entering the manifolds/engine. My fellow Team Baja Marine members also recommend instead of coming to an abrupt stop and cutting the engines (when entering a no-wake area for example) cut back and then "pop" the throttle back again foward briefly to void backspash.
I'm launching May 3rd so I'll let you know more when I actually try this trick.
I can't wait to hear the "rumble of the 'ol 502 w/o the muffled tips. I have Capt. Call so if it gets to loud I can just "flip the switch"!
Attached Thumbnails S/s Corsa Slant Tail Pipes-exhtips2.jpg
steve chalupka is offline
Old 04-21-2002 | 11:08 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
Steve, whats the thru hull fitting for between the tailpipes? Nice clean transom, looks good!
I tried the rubber flappers inside my tailpipes also, blew both of them out the first time I ran it. I use the salisbury type now that clamp on the ends. Kinda hard to do with the angle cut pipes thou. So might keep an eye on them.
Jerry
US1 Fountain is offline
aTX427
Fountain
2
05-22-2008 12:31 AM
CcanDo
24
07-03-2007 08:39 PM
S4Hadi
2
03-12-2006 03:12 PM
GS42fun
2
06-06-2005 07:18 PM
