Prop shipping >
Prop shipping
Prop shipping
Old 03-03-2010 | 08:50 PM
Default Prop shipping
What's the best way to ship a prop as in crate, anyone have any pics of how to build one.
bert4332 is offline
Old 03-04-2010 | 08:36 AM
rchevelle71's Avatar
I just box them up, wrap the prop in bubble wrap, then get an oversized box, double up the cardboard on the inside, fill partway with packing peanuts, place the prop in, then fill the rest of the way with peanuts. If you are leary of this, build one out of plywood, using a long bolt and washers to bolt the prop down to one of the sides.
rchevelle71 is offline
Old 03-04-2010 | 08:59 AM
I just recently shipped a couple to Mercury Racing for refurb. Had a thick cardboard box, cut a top and bottom out of plywood and sandwiched the prop with threaded rod and nuts. Screwed 4-2 x 4's @ the corners, put in the box and filled with peanuts. Held up well and Mercury sent them back in the same boxes.
ciaoderhead is offline
Old 03-05-2010 | 02:02 AM
2 pieces of plywood bigger than the prop diameter with a hole in the center, then run a bolt through the holes and prop center. Then place in a box of appropriate size to keep it from moving around. Cut the plywood to fit tight in the box.
Griff is offline
Old 03-05-2010 | 12:58 PM
hoghead's Avatar
Pretty much what Griff said. Here's how I do it.
http://www.flickr.com/photos/3998522...7623560746848/
hoghead is offline
Old 03-05-2010 | 07:10 PM
offthefront's Avatar
HH .... great way to pack ... seems one step better would be plywood on Both ends? ...... m
offthefront is offline
Old 03-05-2010 | 07:47 PM
hoghead's Avatar
yea, I think another piece of plywood would tighten it up a bit and be a little better.
hoghead is offline
Old 03-05-2010 | 10:55 PM
CB-BLR's Avatar
Chris
No matter how you ship them... insure it!
It is worth every penny if one gets screwed up in shipping.
Chris
CB-BLR is offline
Old 03-06-2010 | 02:14 PM
F.Y.I.
I know this isn't crate related but.....
Check out U.S. postal service rates, I believe they were almost half as cheap to ship 2 props to BBlades than U.P.S. with the same insurance
for me.
johnny b good is offline
Old 03-07-2010 | 07:35 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
hoghead, Great, ok
That's BBLADES packaging. literally.
We do send these packages to people in advance, if they wish to send us their props.......
ciaoderhead,
Merc sent your props back in your boxes cause they figured you wanted them back. Or you told them you did. We/Merc Racing always (in the past while I was there) sent props back from Merc in Merc boxes if the customer boxing was lack luster. Some guys just want their own creations they are proud of back to use again. Your custom box obviously involved time and effort and was as good or most likely better than the Merc Racing stuff! Most folks don't want to take that time.
If anyone wants to use our boxes for storage or shipping to BBLADES or elsewhere, please give us a call.
Brett
[email protected]
bbladesprops is offline
