bravo 1 drive play >
bravo 1 drive play
bravo 1 drive play
Old 03-10-2010 | 07:33 AM
Default bravo 1 drive play
My drives are off was checking the gimbal ring for play i have a tad bit of play in the bottom pin on the gimbal ring and i have 1/6" side play on both helmets inside the ring but no up and down play,any thing i should do.
rssteiny is offline
Old 03-10-2010 | 09:29 AM
Tighten those two nuts at the top of the gimbal facing aft. Do it every season.
Pismo10 is offline
Old 03-10-2010 | 12:37 PM
rssteiny is offline
Old 03-10-2010 | 05:30 PM
the right way is to loosen them and then torque evenly to
53lbs
boatnt is offline
Old 03-10-2010 | 07:33 PM
You can remove the lower swivel shaft by removing the cotter key. The shaft is probably worn out. It also has a bushing that can also be worn out. I can post some pictures if you like.
1BIGJIM is offline
Old 03-11-2010 | 05:32 PM
Yes please
rssteiny is offline
