twin drive
Old 03-12-2010 | 03:56 AM
Default twin drive
do they counter rotate the motor or change the drive on the merc 4.3 and whitch motor do they put the power steering pump on
toprope1 is offline
Old 03-12-2010 | 09:35 AM
Counter rotating Alpha drives are available if that is what you have. You will want to make sure you get the correct generation Alpha with the correct drive ratio for your application.
floatingphil is offline
Old 03-12-2010 | 11:57 AM
also usually the p/s pump is on the starboard motor,closer to the steering rack..
FIXX is offline
Old 03-13-2010 | 05:27 AM
Default 4.3 merc
that motor should have the same rotation as my single 4 cy. merc.? i'm wanting to replace my 4 with the 4.3 in my scarib sport.
toprope1 is offline
