trim tabs for my 20 outlaw..which ones >
Old 03-13-2010 | 07:56 AM
Default trim tabs for my 20 outlaw..which ones
http://www.eddiemarine.com/photos/500-75.jpg
was wondering if anyone has a set of these..and how well they like them.and do you think they would work better than say a set of bennett twin rams.like there st12
http://www.starmarinedepot.com/Benne...port+Tabs.html
i dont think i need to go all the way to k planes.any advice would be great.
450RRRR is offline
Old 03-13-2010 | 09:03 AM
hoozeyurdaddy's Avatar
what kind of performace are we talking about with the outlaw, how much HP, SPEED, Water comditions? these are all things that you need to look at.
hoozeyurdaddy is offline
Old 03-13-2010 | 11:37 AM
on a really calm day i have hit 63 on the gps.260 hp + or -.spend most of my time in or around sarasota bay.want to be able to spend more time in the gulf with out getting so beat up.
450RRRR is offline
Old 03-13-2010 | 12:34 PM
Tabs are not going to help a 20' all that much. They will help, keep the bow down, but thats about it. Any chop over 2' will still be rough.
Griff is offline
Old 03-13-2010 | 12:48 PM
For a 20' boat the bennet tabs should be fine. Like Griff says though, they're not going to help all that much.
Right now I have a set of single ram bennet tabs on my 32' Baja, and they're fine for the boat. You can tell that they have a little trouble handling the weight because they're cupped slightly, but these are single ram (I believe aluminum) plates on a 7200lb. boat. I'm taking them off to install the dual ram plates like you have pictured here. If you're interested I have an extra set of dual piston plates and/or my old setup that will be available in about a month.
wjb21ndtown is offline
Old 03-13-2010 | 12:58 PM
jfm
I have a set of the 12X16's. Plates hinges, hardware, and pistons. NO pump or switch if you are interested.
jfm is offline
Old 03-13-2010 | 02:58 PM
NOBODY LIKES THE EDDIE MARINE BETTER THAN THE BENNETT.sorry caps on.i thought the eddie marine which would give me 5 + in. more surface area per side would be a bigger help over all.plus they appear to be machined.and the rams arent made of plastic.
http://cgi.ebay.com/ebaymotors/Trim-...ssoriesQ5fGear
would these be over kill
450RRRR is offline
Old 03-13-2010 | 03:01 PM
The EMI tabs are better, but are not really going to make a difference over the Bennets in ride quality.
Griff is offline
Old 03-13-2010 | 03:11 PM
jfm
K-planes are nice but they look like they where cut.
jfm is offline
Old 03-13-2010 | 06:05 PM
I have eddies on my boat that I just put on over the winter. I havent tried them on water yet. But they sure look good. I know alot of people have bennetts. I just don't like the look of the 12 ga stainless. Compared to the look of aluminum billet. I know it's just personal preference. I know they are cheaper also. Just my .02
capt2130 is offline
