2009 6.4 Powerstroke.....Best Programmer?
Hi all,
Just traded my 2007 6.0 for a 2009 6.4 pstroke. Which handheld tuners are you 6.4 guys running? I mainly want to increase mileage and am not interested in the dpf delete (even though it is tempting). Curious to see what power gains you have experienced too! Thanks
Tyler
Tyler
Hi all,
Tyler
Tyler
http://innovativediesel.com/
They also have exhaust, turbo and or cat back exhaust..you name it they have it.. Good Luck. Jeff
Hi all,
Tyler
Tyler
yes they did..My 07 went to a member herer..and no problems since last month when we talked on the board..actually do a search and youll see the silver F350 dooly.
I believe they did....I had no trouble with mine. I bought it new and traded with 75k on it. With an intake, tuner, and turbo back exhaust i was getting about 16mpg with 6" lift and 35" tires. I do believe the egr cooler was just starting to leak when I traded though....
For anyone that has a 6.0 Be careful on the 6.0's that if you use a programmer be light on the tune, keep your foot out of it all the time..they will blow head gaskets..my 05 did last week..210k miles of pulling trailers and just a tow tune..
correct 3's and 4's had more problems..5's were improved head studs and thats when they went to springs in the front for a better ride as well. 6's and 7's more changes were made internally for the better. 8's are when the 6.4 came out..I had no problems per say other than they replaced some dripping fluid that I noticed after I read a thread on here..they actually replaced the entire cooling system at no charge..The 08 6.4 Truck was awesome..I really enjoyed it. Pulled the NorTech well...and I left it completely stock.
