Maximus or P5x? Best bow lift?
Which of these two props has the most bow lift (least stern lift)?
A 15".. short tube.. Maximus
or
A P5x
The boat is a Nordic Heat (28ft, single engine, v-hull)
Prop shaft is at 3.5" below the keel, with a stepped hull, and a notched transom.
Current speed is 92-93 mph.
Speed with new motor should be over 100 mph.
Chris
or
A P5x
Chris
or
A P5x
Chris
or
A P5x
Chris
Depends on the full Max recipe.
We can create way more bow lift with a 15" Max with the diff. removed than with the P5X. However, the P5X in stock form has more bow lift than the stock Maximus.
Brett
Brett
[email protected]
[email protected]
