Which thermostat in a 454SC engine?
Have newly rebuilt 454 with 177 Blowers. Had high flow brass thermostats when I got the boat. Stats say V142 and 4H7 on the bottom. Should I stick with this style stat and keep water temp at 140? Engines have crossovers.
Keep water temp at 140F. Sea water has salts, other than table salt, that precipitate at higher temps causing scale in the water passages of the block and heads. See you are in CT so the sea water part applies to you right?
Long time cult member.
