Marine (white) Clarion 12 Disc Changer... >
Old 04-22-2002 | 09:18 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Marine (white) Clarion 12 Disc Changer...
Does anyone have this unit?? I just bought one from BillR, and am going to install it soon. My dilemna...
BillR said it worked best installed vertically.
AudioFN said it works best installed horizontally.
Does anyone else have 2 Cents to add on this unit inparticular only? All players and changers like different angles, some even do best at 45*. I just want to know specifics on this unit, and don't want to have to install twice.
Thanks!!
Sydwayz is offline
Old 04-22-2002 | 11:04 AM
Audiofn's Avatar
Charter Member #232
Hold it horizontal and smack it around and then vertical and smack it around, see what works best
Put your best foot forward!
Audiofn is offline
Old 04-22-2002 | 11:07 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Ah, so I treat it just like a Girlfriend then??
(just kidding everyone)
Sydwayz is offline
Old 04-22-2002 | 11:16 AM
Audiofn's Avatar
Charter Member #232
It has been my experience that most changers work best when laying on their side. Make sure you set it up for what ever position you put it in. Make sure you adjuct the spring for the suspension on the side. The Changer is build most of them to lay flat so the carier mech has equal load on all the suspension, and also the lens can track and is less likely to bounce. Again this has been my experience.
Jon
Audiofn is offline
Old 04-22-2002 | 11:37 AM
BAJA WILL's Avatar
Registered User
Brian,
It all depends, we all know how you keep the Sonic Vertical, when jumping waves
BAJA WILL is offline
Old 04-22-2002 | 11:39 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
True that! Let me be the first to add horizon and pitch inicators to a Sonic.
For explaination click here.
Good one Will.
Sydwayz is offline
Old 04-22-2002 | 01:09 PM
BillR's Avatar
OSO Moderator
I had mine mounted Horizontally, never a problem!
In my experience, the Clarion's are SO stable, mount it which ever way you want and you'll be fine.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Old 04-23-2002 | 12:32 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
My mistake BillR, I thought you said vertical when I bought it. I guess it is going in horzontal then.
Sydwayz is offline
TomFTM
09-15-2007 10:09 AM
imartin
Baja
2
03-23-2007 12:16 PM
SeaWeasel
3
04-14-2005 07:53 AM
jafo272
0
11-03-2002 04:56 PM
Raypanic
01-26-2002 09:38 PM
