-2 IMCO Shorty Install >
Old 03-30-2010 | 07:34 PM
GB
Default -2 IMCO Shorty Install
Will be swapping out the Bravo lower this weekend. All pointers welcome.
Thanx
GB is offline
Old 03-30-2010 | 07:43 PM
it will install just like the merc lower,always replace the quad ring with a new one every time you remove a lowewr.
mike tkach is offline
Old 03-30-2010 | 10:32 PM
Mike, what's a quad ring?
AO31 is offline
Old 03-30-2010 | 10:45 PM
Default Fixx
its that little orange seal that goes between the upper and lower for the oil passage.. i also greece the splines with spline greece.
FIXX is offline
Old 03-30-2010 | 10:52 PM
Gotcha, didn't know that is what it's called
AO31 is offline
Old 03-31-2010 | 01:11 AM
Its pretty easy and straight forward to swap lowers
Griff is offline
Old 03-31-2010 | 04:36 AM
Mr Gadgets's Avatar
Charter Member #601
Make sure the bolts for the anode on the front of the upper housing dont interfere with the new lower. Usually they are too long and wont let it seat properly. I use a 1/4" shorter SS bolt and all will be good. You can just cut yours down if you want to. Imco supplies a white hard plastic Oring to replace the quad seal, both are good pieces. If you are not using the speedo pickup, put the 1/8" pipe plug in that hole. Some have drilled that plug to relieve high water psi.
Thats all I can think of for now.
Hope that helps.
Dick
Mr Gadgets is offline
Old 03-31-2010 | 06:59 AM
BRUCE SEROFF's Avatar
And......make sure to put all your O rings back. Seen alot of blown drives because of this.
BRUCE SEROFF is offline
Old 03-31-2010 | 01:39 PM
GB
Thanx for the info. When the box arrived, there were no real specifics called out in the instructions.
GB
GB is offline
