Pully Back lash on 177 Blower >
Old 04-01-2010 | 01:51 PM
Default Pully Back lash on 177 Blower
Anyone know how much back lash or "back and forth play" is acceptable for the pully on a Wieand 177 blower. I have 2 blowers and one has more back lash than the other.
kreed is offline
Old 04-01-2010 | 02:39 PM
Nicolasticity's Avatar
Is the backlash anything to do with the tensioner spring strength?
Nicolasticity is offline
Old 04-01-2010 | 09:49 PM
disregard....thought you were talking about the tensioner.
Griff is offline
Old 04-01-2010 | 10:41 PM
How many hours are on it? It could be wear/play in the coupling. You should rebuild them every 350-400 hours,
Bodi is offline
Old 04-02-2010 | 06:31 AM
I believe there is about 200 hrs on them. Just that when you hold rotors inside blower stationary, and then by hand , try to turn the pulley back and forth, the pulley on one blower has more "back lash or end play" than the pulley on the other blower. Just wanted make sure this " back lash" wasnt out of tolerence.
kreed is offline
Old 04-02-2010 | 05:50 PM
There is no axial movement on those input shafts. The snout bearing is pressed on and the assy is held in the housing with a shoulder machined in the back and a snap ring in front. Pull the snout off and check it out.
Old Navy is offline
