Total timing ??? >
Total timing ???
Total timing ???
Old 04-01-2010 | 08:34 PM
Default Total timing ???
What is the correct way to set the total timing with a dial back timing light. Do I just set the dial for say 35 degree's and adjust the distrubitor to the timing is at zero on the balancer. Or I start at 10 degree's and dial 35 on the toming light and adjust the distrubitor to zero on the balancer. Some info would be great Jp
alecsammy is offline
Old 04-01-2010 | 09:41 PM
35* on the dial and balancer mark at 0
Griff is offline
Old 04-01-2010 | 10:12 PM
Default Fixx
what griff said then you have to rev the engine over 3500 or until its at total advance and chech the ballancer..
FIXX is offline
Old 04-02-2010 | 12:17 AM
fastlane40's Avatar
Only way you should be setting total timing is at maximum advance revs.If you know what revs total timing advance is achieved.Run it a bit past and thats how you set it.
fastlane40 is offline
Old 04-02-2010 | 08:39 PM
