x dimensions
Old 04-02-2010 | 08:32 AM
Default x dimensions
hey guys i need your help im fitting a bravo on a pantera 28
but i havent got a clue what x dimensions means
i was told 1" but where do i measure from and to
any help would be great
cheers
gerard is offline
Old 04-02-2010 | 08:56 AM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
x-dim refers to the distance from the bottom of the hull to the center line of the crankshaft.
On a standard bravo the distance from the prop shaft to the input shaft is 21-13/16
I am assuming the 1" dimension you talk about is having the prop shaft 1" below the bottom of hull this would equate to a x-dim of 20-13/16.
If he meant 1 inch above the bottom of the hull the x-dim wouild be 22-13/16
File Type: pdf
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Old 04-02-2010 | 08:58 AM
thanks for your reply
i meant to say 17" x dimensions
cheers
gerard is offline
Old 04-02-2010 | 09:59 AM
Do a search this has been covered many times, I have one that is under the "Drives" section called "what is your drive height". I raised mine up 3" from stock, I think the x went from 15.25" to 18.25". All boats are different, too low too slow, too high and it will not plane off.
jeffswav is offline
Old 04-02-2010 | 10:05 AM
what type of boat did you have and what gain did you get
thankyou
gerard is offline
Old 04-02-2010 | 11:19 AM
17" is the correct X for a 28 Pantera. That puts the propshaft height at about 4.75" below the bottom.
Griff is offline
Old 04-02-2010 | 12:59 PM
thankyou
Baja 236, I don't know yet have not hit the water yet.
jeffswav is offline
Old 04-03-2010 | 01:08 AM
Single engine pleasure 28 Panteras need the X at 17" and thats even agressive. Any higher and its hard to carry the bow. You can go to about 17.5 or maybe 18 on a lighter race/poker run boat with no cabin.
Griff is offline
Old 04-03-2010 | 09:43 AM
17 was the height set in factory racing.
SVL-WARLOCK is offline
