What prop is standard on a 260 w/496 mag >
Old 04-03-2010 | 12:54 AM
Default What prop is standard on a 260 w/496 mag
As title states I was looking for any info on the "stock" prop on a 260 w/496 mag and bravo. I am tossing the Sportmaster that came on my 260 when I purchased and am putting a standard Bravo lower on. So I want to put the right prop on it. Thanx in advance!!!
low_psi is offline
Old 04-03-2010 | 05:26 AM
i would think either a 24 4 blade or a 23 3 blade depending on your prefrence..
mookymonkey is offline
Old 04-03-2010 | 09:39 AM
mikes280's Avatar
my guess would be a 26 hydro 4 blade , velocity's don't like 3 blades the x is to high. MY 280 had a 365 mag 454 in it stock and it came with a 24 hydro 4 balde so with you boat being 2 ft smaller and more power i would think it would need a bigger prop
mikes280 is offline
Old 04-03-2010 | 10:50 AM
Right now I have a 26p Bravo 1 on the Sportmaster 1.26 Drive. So I guess I will give it a try first.
Right now with the 1.26 lower it will only get up to about 4500 RPM. I have a 1.5 Bravo lower on order.
low_psi is offline
Old 04-03-2010 | 02:24 PM
Mikes right you're boat will not even get on plain with a 3 blade. 24 bravo 1 work really good on my boat, but I'm at 4800 feet
stoltz is offline
Old 04-03-2010 | 03:04 PM
I have my eye on a Hydromotive 27P 4 blade prop that has been "cupped to a 26p" Not sure what that really means.... But at the price I might give it a shot.
low_psi is offline
Old 04-03-2010 | 05:00 PM
a hydro 27 might be a bit steep for your boat, even if it is cupped. i have a 27p hydro comin that i will be testing on my 260 with a 500efi as soon as my new xr gets in, i will update how that works out as soon as i know. i would try the 26p b1 that you have now and then go from there.
rmfriday is offline
Old 04-03-2010 | 06:45 PM
Yeah, I had my doubts about a 27p being cupped to a 26p. They guy was selling for $300. I found a website that is selling Hydromotive Quad-4 s for $595. I will call Hydro direct on monday to see what they sell direct for. But honestly for an extra $300 I'd rather buy a new one. I guess I thought the hydromotive would be more than $600.
low_psi is offline
Old 04-03-2010 | 07:43 PM
If you want a bravo 1 26 , i have one that is perfect shape for $325.00 shipped
fastscarab22 is offline
Old 04-03-2010 | 10:28 PM
Thanx, but already have a bravo 1 26p.
low_psi is offline
