Speedometer water passage in lower >
Old 04-04-2010 | 01:56 PM
Default Speedometer water passage in lower
Is there a way to plug speedo water passage in lower without threading and screwing a plug in. If not using I know it needs to be plugged. What will happen if not plugged? Any help would be great
firehawkcat is offline
Old 04-04-2010 | 08:17 PM
If you cut the hose on the outside of the lower unit, inside of the helmet, it will just blow out a little water and not hurt anything.
speedreeder is offline
Old 04-04-2010 | 09:03 PM
I have a -2imco,drive spacer and a new teague xr just dont want to trash the shbang the first on the water
first time on the water that is
Old 04-05-2010 | 01:58 AM
There should be a small hose on the leading edge of the drive just above the where the lower meets the upper, that could just be disconnected.
Griff is offline
