Know where I can find a cheap ecu for 5.7 EFI >
Old 04-22-2002 | 09:28 PM
mlitefan
Default Know where I can find a cheap ecu for 5.7 EFI
2000/2001 bravo 3 setup???
A buddy needs one fast...
Old 04-22-2002 | 11:02 PM
did you look in the classified section of OSO?
OffshoreOnly is offline
Old 04-23-2002 | 09:14 AM
mlitefan
I looked and didn't find anything. I was hoping someone had a takeout 350 that they stripped for parts.
Anyone?
Old 04-23-2002 | 09:33 AM
I have a complete setup off of a 1996 5.7LX. Includes intake, ECM, distributor, VST, etc. $350.00 complete. I won't seperate. Call (920)743-7842 if this helps.
MARK BENTLEY is offline
Old 04-23-2002 | 10:12 AM
Kokopelli's Avatar
I have an ECU off a 454 mag mpi. If its the same part, AZ speed and Marine could reflash it for 5.7 use. Off a 96 454 mag efi. Had 50 hrs before replaced it with a trick ecu from AZ speed and marine after installing blower. It is a merc. check sum # 9402. Delco model number 16234539. These babys are $5-600 new. I'll take $200.
Kokopelli is offline
Old 04-23-2002 | 10:31 AM
mlitefan
Thanks for the response! I don't think that will work. The part number on his ECU is different thatn the one you have. I have no idea what the difference is or even if there is a difference.
Anyone know?
Believe it or not, the ECU for his engine lists at $1200.00 bucks!
Old 08-24-2009 | 12:40 PM
Default Anyone know where i can get a cheap ECU?
model # 16234539--Delco out of a 350 mag efi gen+
Thanks!
riverrat928 is offline
Old 08-24-2009 | 02:01 PM
klaw's Avatar
Charter Member #139 /Moderator/Platinum Member
wow original post is from 2002 and thread starter appears not to be a member anymore
Kept the Bullet and the condo and joined the cig 20 restoration club.
klaw is offline
Elite Marine
Swap Shop
0
09-20-2008 08:51 AM
fbh-velocity
1
07-29-2007 03:49 PM
roarkace
0
11-28-2006 06:43 AM
sleeper_dave
11-16-2006 05:11 PM
Raypanic
4
05-05-2006 08:26 AM
