What size are the cup holders in the Baja's? >
Old 04-08-2010 | 02:06 PM
Default What size are the cup holders in the Baja's?
Trying to order some from eddie marine and not sure if the baja's have 3 inch holder or the bigger one. I'm thinking off hand boat is away right now I need 8 for my 29
bajaboatnut is offline
Old 04-08-2010 | 02:36 PM
2 different sizes probably...My hammer has 2 different sizes and I've got a buddy with a 25OL that's got both sizes as well
Here's the most helpful thread I've found on it, and it's not much help...
http://www.offshoreonly.com/forums/b...p-holders.html
boogy886 is offline
Old 04-09-2010 | 11:14 AM
From: Northern, KY (Cincinnati) Lake St Clair, MI Norris Lake, TN
You need the large. They are all the same size.
http://www.eddiemarine.com/store/car...l&p=12278&c=82
Baja_342 is offline
Old 04-09-2010 | 02:12 PM
I replaced all of mine with the aluminum ones except the front passenger one. The grab handle is in the way. I can get the old plastic one out but not the new one in. I'm going to have to remove the handle but it is blind side mounted and I haven't gotten to pulling the panel off to get to the mounting screws.
BajaFresh is offline
Old 04-10-2010 | 06:04 AM
I changed all of mine and didn't have to remove the handle. If you get the large ones you will have to make the existing hole bigger. I shaved enough (toward the radio) to get the new one in. The rim at the top covers the entire area. It was tight but doable. Hope this helps.
indywhsle is offline
Old 04-10-2010 | 09:40 AM
Indy did the large ones work for all 8
Old 04-10-2010 | 12:42 PM
Yes all 8 are the large ones. Just have to make the existing hole a little bigger. That is the only option. The next size down is too small.
Old 04-11-2010 | 12:34 AM
thanks
Old 04-16-2010 | 05:55 PM
JasonSmith's Avatar
You gotta tilt the cupholder in the hole to get it out. I can take mine out & it is trick, but it will come out without having to remove the handle. Unless your handle is just mounted really low.
JasonSmith is offline
Old 04-16-2010 | 06:04 PM
Where the He!!'s the color chart! There are 3 blues and lime green. Do I do blue..blue or blue or lime green in my 29??? Suggestions? (boat is blue and lime)...oh and gauge bezels...lime or chrome?
HOSSMAN is offline
