2005 new 2.5 merc efi o/b
Old 04-08-2010 | 07:06 PM
Default 2005 new 2.5 merc efi o/b
any one know fuel burn on a 30 ft twin sport boat
firebaseball is offline
Old 04-08-2010 | 07:07 PM
with this motor set up twin 2,5 merc outboard racing motors
Old 04-08-2010 | 07:37 PM
Ryan Beckley's Avatar
Racer
Racer
1-2 gallons per mile - per motor at WOT
Ryan Beckley is offline
Old 04-09-2010 | 09:15 AM
crazyfast's Avatar
Fire...u need to really look at my PowerPlay
crazyfast is offline
Old 04-09-2010 | 02:04 PM
Kanookstr's Avatar
32' SUNSATION
I own twin 2004 2.5 efi (280 HP each) on a 4500 lbs boat and I can tell you that they use a lot more gas than my 32' sunsation 7000lbs += with twin 496 HO (425 HP each)
Kanookstr is offline
Old 04-10-2010 | 10:33 AM
Default fuel burn
Around 28 gallon/hour full throttle
stirling is offline
Old 04-13-2010 | 11:56 AM
Hi!
I have two Merc 2.5 EFI SS 280 hp engines with PCU's which helps a lot on the fuel consumption. I use approx. 75 litre / 20 gallon per hour running 4,000 rpms at 52 mph. My boat is 25 feet offshore hull with weight of approx. 3,000 lbs. When I ran a single Promax 300 3 litre the fuel consumption was 55 litre / 15 gallon an hour at the same speed and rpm. So I am pleased with the two Merc's, although Brucato PCU is vital for these numbers.
Cheeers and good luck, Toffen
Toffen is offline
