Fuel return  regulator >
Old 04-10-2010 | 01:11 AM
Default Fuel return regulator
If I have a fuel return regulator and I can not return it back to my tank were is the next best place for it?
dennis r is offline
Old 04-10-2010 | 01:26 AM
MerCruiser takes it back to the fuel filter assembly/adapter.
Boat Tech is offline
Old 04-10-2010 | 05:18 AM
Vinny P's Avatar
I hate the winter!!
How about the fuel filler hose? If you can get to it, you can T the return into it.
Vinny P is offline
Old 04-10-2010 | 07:36 AM
tmdog's Avatar
Did you mean fuel "vent" hose? Install a "Y" fitting and good to go.
tmdog is offline
Old 04-10-2010 | 08:22 AM
hoozeyurdaddy's Avatar
No, he means the filler hose 1&1/4 in hose, go into CP performance and find the fittings you need, I got 2 of them 2 years ago.
hoozeyurdaddy is offline
Old 04-10-2010 | 05:51 PM
H2Xmark's Avatar
that's the way they rigged my Fountain when they put the 500efi's in it,
H2Xmark is offline
Old 04-10-2010 | 06:00 PM
I've always returned back into fuel filter housing provided it has another in port.
steveh1209 is offline
Old 04-11-2010 | 12:32 AM
It is just a bad idea to return to the filter. If you have a small pump on a relatively low hp engine, you can get away with it. As soon as you step up in power and fuel pump, you are asking for trouble. Not only will it heat up the fuel (even with a cooler), but it will continuously aerate the fuel. I will only set one up with a return to the tank. If you can get to the tank at all, then give me a call and I can give you a trick to make a return in the tank. The tank fill hose is another good option. Definitely do not use the vent hose.
Eddie
Young Performance is offline
