engine cuts out momentarily when hitting hard waves... >
Old 04-11-2010 | 08:49 AM
Default engine cuts out momentarily when hitting hard waves...
Just as the title says, engine is cutting out when hitting waves hard. I've checked all power and ground connectiions, all ignition wiring and kill switch...
Got any ideas?
1994 baja 272 with carb hp500
SmurfOnABoat is offline
Old 04-11-2010 | 09:05 AM
Got any ideas?
On a hp 500 carb it can be the coil. They way they are mounted causes issues.
Thansk
Steve
smiklos@sunprint is offline
Old 04-11-2010 | 09:22 AM
Any way to check, and what do you need to do to fix the mounting?
Old 04-11-2010 | 09:55 AM
Smitty's Avatar
Coils are cheap. Just get a new one. You really cannot test them in real world conditions.
Personally I would double check all connections in the path for the ignition. Another slight possibility is the float level in the carb is not perfect and when you jar the boat, you might be causing a momentary lack of fuel or a shot of too much.
Smitty is offline
Old 04-11-2010 | 10:02 AM
Michigan Mad Man
I have run into the same thing before and I found the nut loose on the back of the 50 amp breaker.
TylerCrockett is offline
Old 04-11-2010 | 11:29 AM
Thanks guys, I will innstall a new coil, this one looks OE, so its worth the change annyways. I will check out the other parts of the system, and the breaker nut.
What coiil should I replace with OE merc or other?
Old 04-11-2010 | 11:49 AM
GPM
Is there a module in the distributor
GPM is offline
Old 04-11-2010 | 02:56 PM
Hitting the limiter? Is the boat coming out of the water?
RaggedEdge is offline
Old 04-11-2010 | 03:41 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
You double checked the large engine wiring harness plug with the hose clamp on it? Seen those come loose and do same as yours is.
US1 Fountain is offline
Old 04-11-2010 | 03:56 PM
spazboz's Avatar
I had the same problem with the Nova When I first got it. The Port motor would cut in and out bad in higher seas. I finally got so pissed one day I punched the dash with my fist in the channel and it did it again. Turns out the ignition switch was bad. But on the trailer in the driveway it worked perfect.
spazboz is offline
