ye haw
finally got the tub on the water yesterday for the first run after the headers and other minor mods my mechanic installed
water was quite rough and the wind was at least 20 out of the north but we just touched 70 on the gps at 5000 rpm with a labbed 25p mirage prop
some small adjustments to make and a minor oil leak on 1 of the filter lines to fix but other than that shes good to go
tremendous amount of slip on the mirage prop though, out of the hole and through the midrange if the trim wasnt just right
we just put this prop on for the test run im hoping to see the same numbers with bravo 1 props
ive purchased a bravo 1 24 pitch and curently looking for a good used labbed 26p bravo 1
THANKS HUGE!!!!!!!!!!!
ohhhhh to be so centsless......
