mirror for engine hatch >
Old 04-14-2010 | 07:42 PM
Default mirror for engine hatch
I saw a thread a while back but cant remember what product was best to use and also how to install
AB69Z is offline
Old 04-15-2010 | 12:58 AM
Go to a local plastics place and order mirrored acrylic. Glue it on with some 4200 or 5200 and maybe screws on the corners.
Griff is offline
Old 04-15-2010 | 06:21 AM
thats the correct material, we use it in my sign shop, but if you use screws, put trim around it and screw that, do NOT screw thru the material itself as it will crack at some point..Rob
ezstriper is offline
Old 04-15-2010 | 09:54 AM
I pulled the mirror of my '98 Hustler Slingshot last month, had to take it off to get to the sun pad. Mine had 1 1/2"x 3/4" furring strips glassed to the under hatch and screwed to the hatch. The acrylic mirror had a luan subflooring glued to the acrylic. The mirror had holes drilled into it, rubber grommets around the holes with a screw holding it to the furring strips. This came from that factory this way. mirror for engine hatch-p3130174.jpg
dicdik is offline
Old 04-15-2010 | 09:22 PM
zt260's Avatar
Mirror finsh stainless steel sheet metal is the best solution. It won't crack or warp. I've had both, and the stainless is still there 5 years later.
zt260 is offline
