500 efi's die together >
Old 04-18-2010 | 05:17 PM
Steel Outlawed's Avatar
Default 500 efi's die together
We were out running today for the first time this season and both engines die at the exact same time. We have drive and tab power and cabin dc power, but no power anywhere else. I did have to replace the starter fuse on the satrboard engine this winter. If it blew is there anyway it could make the one on the port engine blow also? There is no power on the dash, or any of the switches on the dash. Could the starboard engine control power to both engines?
Any help would be appreciated.
Steel Outlawed is offline
Old 04-18-2010 | 05:48 PM
Problem with the kill switch??????
Padraig is offline
Old 04-18-2010 | 06:27 PM
It is still entact, it did not get pulled I checked that. Now the switch itself could be bad. The engine hatch power is dead also, so I gave up for today. I will have to get the hatch open before I can check anyhting in the engine compartment.
Old 04-18-2010 | 06:41 PM
Kill switch will only cut power to the ignition.
1BIGJIM is offline
Old 04-18-2010 | 06:48 PM
Default Fixx
Check the battery switch terminals..probably a bad switch or loose cables..if the switch is melted the cables were probably loose....Replace the switch.
FIXX is offline
Old 04-18-2010 | 06:52 PM
Could this have killed both engines at the same time? I have 2 batteries and 2 switches. I was running both switches on number one at the time.
Old 04-18-2010 | 07:04 PM
Default Fixx
go to the one that goes to the engines,,if one switch feeds the other then yes it could kill both engines..you have no power no where so start at the main source and trouble shoot from their..
FIXX is offline
Old 04-18-2010 | 07:19 PM
One switch feeds one engine and the other feeds the other engine.
Old 04-19-2010 | 07:32 AM
is the ground connected,,,to both of the switches???
TWIN-SPINS is offline
Old 04-19-2010 | 07:42 AM
No, sererate grounds from both switches. The engines are grounded together though.
