circ pump to crossover hoses ? >
Old 04-20-2010 | 08:14 AM
Default circ pump to crossover hoses ?
on my 500hp w/ gills i have 4 hoses coming of the stock t/stst housing to my gills 2 go down to the bottom rails on the manifolds and the othe 2 go to the back side upper part of the manifolds they are the 2 that come off the brass peice with the spring loaded check balls in it. my crossover only has 2 outlets so how do i plumb this system.
rssteiny is offline
Old 04-20-2010 | 08:18 AM
Default pics
pics
Attached Thumbnails circ pump to crossover hoses ?-100_6894-600-x-450-.jpg   circ pump to crossover hoses ?-100_6898-600-x-450-.jpg
rssteiny is offline
Old 04-20-2010 | 09:53 AM
get rid of the check valve and install a 90 or staright fitting,hook the existing hose that goes to the riser and run the water feed hose into the bottom of the manifold like shown in the pic..
http://www.cpperformance.com/detail.aspx?ID=2943
FIXX is offline
Old 04-20-2010 | 08:09 PM
Thunderstruck's Avatar
Call Gil and get hoses and hose barbs that takes out the tee on the manifolds. The hoses route the manifold water to the riser.
Attached Thumbnails circ pump to crossover hoses ?-img00044.jpg   circ pump to crossover hoses ?-img00042.jpg
Long time cult member.
Thunderstruck is offline
