Drive swap >
Drive swap
Drive swap
Old 04-23-2002 | 11:30 PM
Chummy
Question Drive swap
A Buddy of mine recently swaped the drives on his 38 Fever so that the props turn inward instead of outward. He was told it would have better bow lift, but now it doesn't seem to have any bow lift. Any advice will be appreciated. Thanks
Old 04-24-2002 | 12:23 AM
candyman35's Avatar
Chummy,
With Bravo drives you just need to run the shifter in reverse and reverse the props to spin the other direction for testing. Turning the props in won't help with bow lift and probably slowed his boat down. Fountain started running the props in on his step hull boats. What year is his 38'? What power, props, drives? Certain props will give you more bow lift others lift the stern.
Dan
candyman35 is offline
Old 04-24-2002 | 05:22 PM
Chummy
Its a 89 with 454's with blowers and TRS drives. It did slow down a lot. We are putting them back tomorrow.
Old 05-02-2002 | 03:14 PM
E Z TERMS
depending on the props .........it'll lift the stern a little or a lot........
mine turn in..........they make it a little faster..............but its not worth it......................drives like crap around the dock and makes it drive spooky over the crest of lengthwise waves
just my .02
ez
Old 01-30-2005 | 08:10 PM
50boat's Avatar
Default Re: Drive swap
switzing drives was work you didnt have to do . ok know heres a thought put on a 100 hours or so , then trade drives, and props, ok know you will be running on the back side of the gear. to ballance wear. go anouther 100 hr and swop back
50boat is offline
Old 01-31-2005 | 07:26 AM
Zanie's Avatar
Read post #3!
It's a TRS boat!
Dedicated L&R drives!
Zanie is offline
Old 01-31-2005 | 07:43 AM
With that year Fountain they need to spin out....What props are they?
Back4More is offline
Old 01-31-2005 | 09:31 AM
Wally's Avatar
Were doomed!
On TRS drives you DO have to swap drives.......you cant run the trans in reverse to go forward.....it will burn up the clutches in no time!
-Wally
Wally is offline
Old 01-31-2005 | 01:33 PM
aTX427's Avatar
my 2000 38 lightning spins in
aTX427 is offline
Old 01-31-2005 | 06:27 PM
H2Xmark's Avatar
[QUOTE=E Z TERMS]depending on the props .........it'll lift the stern a little or a lot........
just my .02
Hey whats going on??? are you going to the TOPPS [turtle club] meeting this Friday night ?? I wont be able to make it but will catch the one in March at Crawdaddys
Mark Rush
H2Xmark is offline
