Y2K prop testing >
Y2K prop testing
Y2K prop testing
Old 04-23-2010 | 09:38 PM
Registered User
Default Y2K prop testing
ok, let's get started with prop stuff...
casual testing (not using the digital tach readout)
2005 Y2K hull #16
prop: unknown bravo 26P
drive: BRV1X 1.5:1 with spacer (unknown height)
4450rpm/58.6mph
top speed so far 62.5 but I don't know what the RPM was
will do some more organized testing soon
rbarna is offline
Old 04-24-2010 | 10:12 AM
Superbabi's Avatar
Top speed of 62.5 ??? if i remember, i thought Keith had your Y2K all dialed in at 71-72 with the correct prop.
Superbabi is offline
Old 04-24-2010 | 03:58 PM
Registered User
To be clear I have not done a WOT pass to test for top speed. I'm working my way up to it. Want to be sure I understand how the boat handles before doing that.
Just being safe.
rbarna is offline
Old 04-25-2010 | 06:54 AM
When I ran bravos on my 30 it like box stock bravos the best. Thick with lots of cup.
z.zuperboat is offline
Old 04-27-2010 | 09:25 PM
krakmeup's Avatar
Easily 72 mph. Best ever was 74.1 on GPS, trimmed and a light load. Be sure you have good water then raise those big K-planes up all the way, and hang on...
Prop supplied is what Coen installed and worked best of many I tried, a stock Merc Bravo I, 26P, un-labbed, RH
The best prop I tried was a P5 (or was it called PX-5???), LH, Hydro round ear
The spacer is 1" and made BIG change, for the better - more bow lift (needed) and carried the nose far better at speed.
Will find my prop spreadsheet and post/send it to ya...
K
krakmeup is offline
Old 04-27-2010 | 09:32 PM
Registered User
Keith-
Thanks for chiming in!
what was good about the P5?
what sort of max RPM am I looking for?
I definitely run with the planes up as much as possible, just drag port to stay level.
Thanks!
rbarna is offline
Old 04-28-2010 | 09:32 AM
krakmeup's Avatar
Merc says max RPM on the 496Mag HO is 5000 rpm w rev limiter @ 5200.
The P5 removed much of the torque steer and came out of the hole very nice, think it added a little mph.
krakmeup is offline
Old 04-28-2010 | 09:50 AM
Registered User
Interesting. Do you remember or have the specs on the P5?
If weather clears up and the logs clear up I will do some 5000rpm runs this weekend.
rbarna is offline
Old 04-28-2010 | 10:01 AM
Pat McPherson's Avatar
You want the P5-X which is basically a 5 blade Bravo 1.
Patrick
Pat McPherson is offline
Old 04-28-2010 | 02:45 PM
krakmeup's Avatar
Thanks Pat! Couldn't remember on the P5-X.
Found my data, see if you can open and read this:
File Type: pdf
krakmeup is offline
