outdrive
Be sure that if you go with the Merc HP lube (which is what Merc specs for my Alpha Gen II) you drain all the old oil out and let it sit a while for a full drain as Merc says not ot mix the HP and regular Merc gear lube. Just in case you have lube other than the HP stuff.
