looking for a part for a trs outdrive >
Old 04-27-2010 | 01:56 AM
Default looking for a part for a trs outdrive
im looking for the input shaft that goes from the out drive into the tranny. has a u joint on one end that goes into the yoke and then a splined shaft on the other end.. i dont know the proper name i guess and dont even know what to search ... anyone know what im looking for and a good website i could get one from? for a trs drive off a 86 chris craft 390 stinger thanks for any help!
jslowss is offline
Old 04-27-2010 | 04:32 AM
c_deezy's Avatar
http://www.mercruiserparts.com/Show_...+GEAR+ASSEMBLY
Part number 35 my man, depending on which transmission you have (Merctrans or Borg Warner).
c_deezy is offline
Old 04-27-2010 | 06:28 AM
Audiofn's Avatar
Charter Member #232
Need to know what tranny you have to know what one you need. They are different depending on if it is a Merc Trans or a Borge Warner.
Jon
Put your best foot forward!
Audiofn is offline
Old 04-27-2010 | 10:22 AM
Borg-Warner has the splines on the outside of the shaft,externally. Merc Trans has the splines internally and a spring on the end. Here's another place where you can get them, a little cheaper.
http://www.perfprotech.com/store/ass...LY,986-50.aspx
picklenjim is offline
Old 04-27-2010 | 04:03 PM
Rookie's Avatar
If you need a Borg Warner input shaft I might have one laying around in my garage.
Rookie is offline
Old 04-27-2010 | 05:01 PM
I might have one for a merc trans
MILD THUNDER is offline
Old 04-27-2010 | 05:09 PM
Just noticed its for a 390 chris craft stinger. More than likely its the borg warner setup
Old 04-27-2010 | 07:39 PM
Rookie's Avatar
Just checked, it is for a Merc trans. I had it removed from the new upper that I bought cause I needed the Borg Warner.
Rookie is offline
Old 04-27-2010 | 10:12 PM
Ya a '86 would be a B-W if it's the original set up. One good thing the B-W shaft is 100 bucks cheaper than the Merc Trans one new.
Old 04-30-2010 | 08:35 PM
Default merc trans
I got two merc style if anyone needs them
redcorvetteman3 is offline
