dumb question??
I live on the coast and cruise alot of the back bays, last summer had trouble fighting sand . Impacted the cooling system on both motors more than once. I've owned several boats (all with alphas) so this is my first bravo. Owner before me did the same and ruined many days of fun.
My question is: motors are out , and I am changing to transom exhaust only . I have made 3/8" stainless block off plates and would like to drill and tap them for a thru fitting . And use it as a higher water pick up , so that I can switch to it while at Idle only and have a fear of the sand and shallow water. I would also put a three way valve in. Problem is a local boat mechanic told me it would not work , it would never get enough water. Maybe i didn't tell him I only wanted it at idle speed. I looked at the gimbals real good since they are out right now ,and i see no reason why it would not work ,especially if i take the exhaust boot out.
Again , please excuse my ignorance. but i really don't want to just go to a high water pick up only and drill another hole in the fiberglass.
I am adding strainers as well. But been told to not have much faith in them stopping the sand problem.
If it were that simple I would have asked a similar question about strainers.....
